Question before Rock Krawler 3.5 Install
I just got the last of everything I needed to lift my 2011 Wrangler Unlimited. I went with the Rock Krawler 3.5 Mid-Arm flex lift, with Bilstein 5100's. Got 35 KM2's and flat black Pro-Comp wheels. And I also bought the AEV Procal to recalibrate.
My question is, do I need anything else before doing this install. We are planning on doing everything on Saturday afternoon, but I am just trying to see who else has used this lift and if there is anything else I need to know before actually tearing into my Jeep! I am hoping I got everything I needed...I even called Rock Krawler and they said the lift is a complete kit, and as long as I got the shocks, then I am good to go! BUT, I just wanted to make sure.....
Thanks for any help!
-Brake fluid
-Grease gun
-Torque wrench
-Drill (for rear track bar relocation mount)
-1/2" drill bit
Everythings pretty easy, I have the same lift, shocks, and tires...During the install if you've got any q's feel free pm me, it'll come straight to my phone.
-Grease gun
-Torque wrench
-1/2" drill bit
I have the 2.5'' RK, so I can speak from experience...
You should really get some extended brake lines, because with any flex they will fail. (I bought the Crown Stainless Steel) Mine were stretched tight with the 2.5'' RK, I can only imagine the 3.5'' RK. Also, extended bump stops would be nice, but not a must. (they are pretty cheap)
I have the RK 3.5 and 35s, drove it daily for a few weeks without bump stops. Went wheeling and did fine that way until I was coming back on a bumpy dirt road. Wasn't long before my rear fenders were hanging and I had to pull them off. Just take it easy and you should be fine.
I also installed some JKS rear coil spring retainers while I had it apart. I didnt like the way the rear coils just sit atop the perch and didnt like the idea of using hose clamps....
