Question about rear sway bar angle
So to fix the pinion angle i'll need adjustable uppers arms instead of lower assuming the pinion angle was all messed up correct ?
I didn't think the rear uppers were needed with a 2.5" lift, damn it.
And I can go all ninja cutting metal, but i can't weld anything
I was checking the JKS adjustable rear spring mount, and i don't think i can't install this as i have the TF rear track bar bracket, so it seems judging at the pictures from the install sheet, that my TF bracket would be right in the middle from the were the JKS spring mount gets installed in the driver side.
I know spring perch wedges are not the end all but you might try a set. They are cheap and easy to install. I have them on mine and coils sit perfect now. I have Rock Krawler.
Rear Coil Spring Correction Wedges
I don't have an angle finder yet, but i took some pictures of my rear DS to see how things look like, i have no idea how the angle should look like, i'll pick an angle finder this afternoon or tomorrow to check live, but does this looks ok or not ?
All views from rear DS
20150922_104559 by SilverFJ RSM, on Flickr
20150922_104608 by SilverFJ RSM, on Flickr
20150922_104702 by SilverFJ RSM, on Flickr
20150922_110614 by SilverFJ RSM, on Flickr
20150922_110625 by SilverFJ RSM, on Flickr
