Question about ORI Struts
So I may be way off tilt here, but I have been thinking about ORI Struts for the rear of my 4 door instead of coilovers. The difficulty I found is whether you plan to onboard the struts, you need to start cutting the tub and if you plan to outboard them, you need full width 1 ton axles with a ton of backspace.
Since I don't necessarily like either of those options I was thinking about the possibilities of a cantilever system using struts. In my mind I picture the evo lever cantilever system replaced with struts.
Picture of the cantilever system:
http://www.evomfg.com/image/cache/da...07-800x534.jpg
Can I I get some feedback on this? I haven't messed with either coilovers or struts yet, but I'm finding these setups more and more enticing as I push my jeep toward higher speed off roading (sand dunes mostly).
Thanks guys.
Thanks guys.
You need to cut the tub no matter which way you mount them. You could maybe shoe horn some 12" struts in without cutting, but I would recommend it. JKU is too heavy to run 12s. 14s, yes, but tub has to be cut.
Struts can't be run in a horizontal position like a coilover. That option is out.
Thanks guys.
Thanks guys.
If your looking for high speed stuff I'd be looking at coilovers instead of struts these tend to heat up when cycled fast it can be done but not the best choice. You might take a look at Rock Krawler's new racer X setup with the coilovers and bypass shocks.
