Question about lift kit and spacers
This may be a stupid question, but here goes. I am going to install a 4" Teraflex short arm lift but I want to level my jeep at the same time. Am I ok adding a 3/4" spring spacer or would i be better off using a body lift?
Most lifts out there, if not all, will in fact level your Jeep. The front will have more lift then the rear to eliminate the front raked look. The only time you might need to add a spacer to level is when you add a heavy bumper and winch.
