Question about length of arms
Hello
I have a big question!!!!!!!.
What is rhe correct lenght or the appropiate dimenseion that i should put on the 8 adjustable arms of the full traction long arm suspension?.
In the Installation Instructions, doesnt say anything about it!!!!!!
Front Lower ?
Front Upper ?
Back Lower ?
Back Upper ?
I hope you can help me!!.
Thanks!!!!!!!!!!
Front Lower ?
Front Upper ?
Back Lower ?
Back Upper ?
Thanks!!!!!!!!!!
Uh, he's lookin for the full traction la measurements, not TF flexarms. The longarms are gonna be quite a bit different on eye to eye measurements.
Thank's
Thank you for the information aldaman but like mkjeeps says, im looking for the FT long flex arms, but im going to check out your information it could be a good start!!!.
Appreciate!!!!!.
Appreciate!!!!!.
Originally Posted by TeraFlex
Suggested alignment information:
For initial settings on control arm length, suggested settings only, I will tell you what we use at our installation
center. Final adjustments need to be made on the alignment rack. The following dimensions are what we use on a 4 door JK with 4 inch lift. These settings will be very close for a 2 door as well. Each vehicle will vary.
Front adjustable track bar - 33 1/8 inches
Rear adjustable track bar - 40 1/8 inches
Front upper control arms - 27 3/4 inches
Driver side front lower control arm - 33 9/16 inches
Passenger side front lower control arm - 33 11/16 inches
Rear upper control arms - 19 1/2 inches
Rear lower control arms - 35 1/8 inches
The different caster from left to right on the front works well on the highway crown we have in Utah to keep the vehicle from drifting to the side. You may find a slight change is required where you live.
All other standard TeraFlex terms and conditions apply to the long arm upgrade kit.
Answer
I found the answer, I send an email to full traction and they send me back the starting measurements of the Control arms. and this is it.
I'm going to put it here if some one need it.
Any way thanks for the Help!!!
Have a nice day!!!!
FULL TRACTION LONG ARM SYSTEM FOR JK WRANGLER
Have a nice day!!!!
