Question about front coil overs and swaybar
It will typically depend on the desired ride height and weight of your jeep minus the axles and tires. For go fast I would think you would want a bigger secondary rate coil. I was just curious on how you cam up with the rates. I would assume you are running a raised rear track bar bracket on the axle to help with roll center as well.
Right, if you can get around a 15 degree angle from the top mount to the bottom mount will help with sway and body roll. This may be hard to do with the factory width axles though. Thanks Mertz, I forgot about that.
