Question: 2012 JKUR Long arm skid plates
I have a 2012 JKU R manual and just purchased a teraflex lcg 4 inch long arm kit.
So my question is what skid plate will work with the long arm kit?
The skid I am most concerned with is the one the one that covers the exhaust. I did get an afe y pipe, I don't know if this makes a differences on needing this skid or not.
Thanks,
Johnathon
Thanks,
Johnathon
JK-Forum Founder
you should be able to run the evo protek skid system without any problems.
http://project-jk.com/jeep-jk-write-...em-for-2012-jk
EDIT: scratch that, i read your post too quickly and realized that you are asking in regards to long arms. these may not work.
Here is the answer I got so far. I don't understand it and waiting for a more detailed reply.
Posting this for info purposes.
You only need that then for the exhaust. However you will more than likely need a new front driveshaft also.
Originally Posted by TeraFlex
Originally Posted by Pjohn
Hi Joe I just purchased a 4 inch LCG long arm kit for my 2012 jku Rubicon. My question to you is what do I need to address the exhaust loop. I bought an afe y pipe. Do I need the loop eliminator as well or some custom exhaust to keep the pipe lengths the same.
Thanks,
Johnathon Regalado
Thanks,
Johnathon Regalado
Welp looks like the little loop before the y pipe can stay. I look forward to getting this lift installed.
You do not need to remove the loop with that y pipe. You can run the stock rear drive shaft.
Still no clue on the skid plate.
