Qaudratec Floor liners question
UPS dropped off my liners yesterday, on the front liners, should I make any cuts to get it to fit over the hook/cleat? I can not get the cleat thru the slot provided?
Should I trim out the entire circle?
Thanks.
Thanks.
You do not need to trim the front. I got some for xmas and the clip just popped in to place to hold them.
edit: I'll see if I can get a picture here shortly when I go grab some lunch.
I couldn't get mine to pop on without a little trimming; and no, you don't have to trim out the entire circle. Start small with minor trimming and test it out. Keep trimming little by little until it pops through. Shouldn't take much.
Good luck,
Dank
Good luck,
Dank
Thanks
I was leary of making any uneeded cuts, I was very careful about making the cut in the rear liner for the factory sub.
I really like the look of these things, I got the full set for Christmas, my wife decided after looking at one of my jeep catalogs, that there were just too many choices, so she let me choose.
Thanks.
Thanks.
I got these for Christmas as well... I did not have to make any cuts other than the rear sub trim. The front clips were difficult to get in, but I managed to gorilla them in there and all is good. Mine came with the little + cut in already.
I was looking at these real closely. Whats the quality like? Any one have the cargo liner? Is it worth the price? Thanks for the info. Im always hesitant to buy online just because you can't get a sense of the quality. Thanks for being my Lab Rat LOL.
I just put mine on, without any cutting. The plastic hook in the floor went only hafl through but after a couple of rides, they simply got in themselves somehow
Hole
I did cut a small hope on the slit- about 1/4 inch diameter. Used a utility knife and then a file to make it look good. The hole makes it much easier to get over the hook.
Also if they are cold they are very hard to get in- even with the hole I need to warm them up in the sun.
