Put Rubi Xfer case on a '12 Sport...
Old 05-28-2014 | 07:23 PM
  #31
JE8154's Avatar
Originally Posted by Matthewd5
I had custom driveshafts made of 4130 thick wall and we went for overkill to not have to worry about them.
Northridge uses Yukon gears
i just always thought that the t case would be the weakest link...
matthew
The tube of the drive shaft isn't what I would be worried about... What joints did they use? 1310? 1350? Yukon gears can fail too, they aren't immune.
Old 05-28-2014 | 07:27 PM
  #32
Matthewd5's Avatar
D44 came with 1310 and D60 came with 1350, we decided to just go with 1310 since it was a factory t case.
how much is a rubicon take off t case worth?
Old 05-28-2014 | 07:31 PM
  #33
JE8154's Avatar
About $1000 depending on availability in your area.
Old 05-28-2014 | 07:35 PM
  #34
Matthewd5's Avatar
Last dumb question for tonight, are all rubicon t cases geared the same?
i have a 2012, wasn't there something about '12 having a t case difference?
Old 05-28-2014 | 07:36 PM
  #35
demtek9's Avatar
You could also get a rubi crawler and get another 2.72 out of your stock t case
Old 05-28-2014 | 07:53 PM
  #36
Matthewd5's Avatar
? Please explain...
Old 05-28-2014 | 07:57 PM
  #37
Roryslife's Avatar
? Please explain...
A rubicrawler is basically an add-on to your transfer case that reduces the gear ratio by half. It only works for 2003 - 2011 automatics.
http://www.advanceadapters.com/categ...bicrawler/237/
Old 05-28-2014 | 07:58 PM
  #38
Roryslife's Avatar
OP has a 2012. Not an option for him.
Old 05-28-2014 | 08:00 PM
  #39
Roryslife's Avatar
Yes, all Rubi cases are geared the same (4:1). The difference is in 2012 and up automatic transmission rubi's. They have the same gearing, but different input shafts.
Old 05-28-2014 | 09:00 PM
  #40
demtek9's Avatar
Oh that sucks. I wheeled with a guy in MOAB that had one and I was impressed. His was a 2010 auto.
Quick Reply: Put Rubi Xfer case on a '12 Sport...
