Pumping handbrake to lock wheels?
Ive heard that if you dont have lockers (like in my sport) you can quickly engage/disengage the hand/parking/e brake (whatever you wana call it) while in 4x4 and while giving your jeep some juice and this will "lock" you tires acting as if your jeep has lockers? Any truth to this? Anybody ever do this? Maybe its a stupid question. Donno. Thanks!
The limited slip is present all the time on those vehicles with that option. Therefore it will exert its influence first, if it's not worn out.
It is made of friction discs on each axle shaft inside the differential.
The BLD is present only when a wheel starts to slip and the traction control applies some brake pressure to the caliper of the spinning wheel.
Therefore it will exert its influence only if the limited slip's capabilities are exceeded.
BLD is present on the driven axles of all JKs.
