Pulling left / rear axle not centered
I'm interested in your findings with the trail grapplers. I have a pull to the left with 35 x 12.50 x 18's. Finally took it in for an alignment, they claimed everything was good, but it still pulls left. I rotate every 5k, but always pulls left.
They recommended cam bolts, but then I saw the rancho or aev control arm drop brackets, but I have no idea if any of that would help with the left pull.
I also disconnected my stock steering stabilizer with no change.
I can post my alignment results if that would help.
https://www.google.com/search?q=radi...a&channel=fflb
Feel free to read through any or all of the results.
I'm interested in your findings with the trail grapplers. I have a pull to the left with 35 x 12.50 x 18's. Finally took it in for an alignment, they claimed everything was good, but it still pulls left. I rotate every 5k, but always pulls left. They recommended cam bolts, but then I saw the rancho or aev control arm drop brackets, but I have no idea if any of that would help with the left pull. I also disconnected my stock steering stabilizer with no change. I can post my alignment results if that would help.
Different wheels/tires = same problem
Here's a reprint of the alignment I had done after my lift. If anyone has any thought?
Would that small amount of caster difference make a difference?? Could it be my rear toe?
I'm still chasing my tail on this so I'm interested to see if you found an answer to your problem?
Does the wheelbase need to be exactly the same left to right or what tolerance is ok? Is a 1/2 inch out ok?
With an adjustable track bar, how close does it have to be? 1/4 inch?
I have trail grapplers also and I have read all about radial pull but if you switch them left to right, that should make them pull the other way correct? I don't see how the tire can cause a left pull regardless of what side of the Jeep the tires on.
I'm still chasing my tail on this so I'm interested to see if you found an answer to your problem? Does the wheelbase need to be exactly the same left to right or what tolerance is ok? Is a 1/2 inch out ok? With an adjustable track bar, how close does it have to be? 1/4 inch? I have trail grapplers also and I have read all about radial pull but if you switch them left to right, that should make them pull the other way correct? I don't see how the tire can cause a left pull regardless of what side of the Jeep the tires on.
