Protecting my underside
#21
Thanks for the input fellas. I've seen the evo stuff and really like the price but I like the one piece design by rock hard and others more. I just feel it will do a better job helping the jeep slide across and breakover issues.
So looks like it's Rock hard skid, riddler diff covers, and Synergy control arm skids.
Would these be the way to go over the basic weld ons or are those not worth the extra money.
Synergy Suspension Jeep JK Rear Lower Control Arm Skids w/ Integrated Shock Mounts
The down side to the one piece systems is that have a tendency to collect trail debris - which can be dangerous if it catches fire. Also, you are worrying about stuff that sits higher than almost all of the drivetrain and suspension. If you are sliding on some of that, you will probably be winching yourself off the rock.
#22
I guess I should have explained what I'm sliding on... I don't do any kind of true rock crawling. Most of my wheeling is done on my family farm and similar trails found in VA. Mainly muddy trails, creek crossings, some hill climbs, etc. Having said that, I have noticed I'm getting hung up occasionally on my crossmember and occasionally dragging the rear diff. A lot of the trails are rutted out to the point that my tires drop in and my underside drags along. I know with larger tires I'll address some of that but thought some skid plates couldn't hurt.
#23
Yeah I am in NOVA. I have been to shoecreek a few time but it has been probably 4 years. I was at red cloud a few weeks ago. I also put a dent in the oil pan there. Lucky it was just a dent.
#24
You may or may not know this, but to my knowledge, lower control arm skids on the FRAME side have not been developed. The synergy weld ons go on the axle end, but to date, the frame end is still a risk..
#25
One AEV rear diff skid. (With a few trail kisses and very nice oil splatter from the last dealership oil change when they filled the oil pan skid)
Attachment 581135
Attachment 581135
#26
Careful with those diff covers, there are clearance issues with certain track bars. The down side to the one piece systems is that have a tendency to collect trail debris - which can be dangerous if it catches fire. Also, you are worrying about stuff that sits higher than almost all of the drivetrain and suspension. If you are sliding on some of that, you will probably be winching yourself off the rock.
#27
Clearance is important to me, as you will see if you watch my build thread where I am doing a front and rear stretch, double triangulated 4 link, all brackets at or above frame and axle level, close to flat skid belly, etc. I'll have a nice fat Sterling 10.5 out back and no diff cover
I'm just saying it is 85% snake oil, but won't hurt anything. I got mine for free and was about to give it away until a friend said people pay money for them. Even with the trail abuse, I got $185 for it! As they say, one mans trash is another mans treasure. Really though, I could make one for less than $50.
#28
Are you referring to the Riddler covers or diff covers in general? And I see what you're saying about debris. My stock transfer case skid collects mud, gravel, etc as it sits right now. I'm hoping larger tires will give me the clearance I'm needing. And eventually I'll probably end up getting 1.5 or 2.5 springs.
#29
I'd say I wheel hard. So far this season I've blown up new Synergy ball joints, front and rear wheels bearings, a drag link, 4 bead lock rings, a driveshaft... And two weekends ago, I blew up my front D44 ring and pinion and my rear pinion bearing. And all my stock brackets are beyond repair, which I am cutting off and welding beef on for the new owner. Clearance is important to me, as you will see if you watch my build thread where I am doing a front and rear stretch, double triangulated 4 link, all brackets at or above frame and axle level, close to flat skid belly, etc. I'll have a nice fat Sterling 10.5 out back and no diff cover I'm just saying it is 85% snake oil, but won't hurt anything. I got mine for free and was about to give it away until a friend said people pay money for them. Even with the trail abuse, I got $185 for it! As they say, one mans trash is another mans treasure. Really though, I could make one for less than $50.
Will check out your build thread.
#30
Breaking things is not a sign of wheelin hard. IMO it is a sign of too much skinny pedal or trying too many times on the wrong line or your rig is just not up to it. The majority of the aftermarket parts could be made for a fraction of the cost to purchase, it is whether the person has the skills or mind to do so.
