Programmers and Cooling Fan
So far I have tried to reprogram the temperature at which my low and high speed cooling fan kicks on with the Aeroforce Gauges (old and new), Superchips, and Banks programmers and none have worked. They all show that the program is set but it doesn't work. I would set it to kick on at 200 degrees and when my jeep was at 220 I would jump out and listen for the fan and no fan, but when it went to 230 degrees the fan would kick on (factory setting). 2012 JKUR
Has anyone been able to verify if a certain programmer will work? When I called these guys they said "not all functions work with all vehicles".
How many threads are you going to start asking the same question?
https://www.jk-forum.com/forums/modi...r-load-336864/
https://www.jk-forum.com/forums/modi...3872-a-327703/
https://www.jk-forum.com/forums/jk-e...egrees-327233/
https://www.jk-forum.com/forums/jk-e...n-temp-324168/
https://www.jk-forum.com/forums/modi...ontrol-336893/
And of course this thread. Asking for advice is one thing, asking the same question over and over again, hoping for a different answer is another.
Get back to the basics as recommended in the recent threads- pull apart the front end and rinse everything again. It may even be a good idea to change your fluid.
I can't say I've had any cooling issues or need for fan adjustment with regular fluid changes and staying away from debris in the radiator.
