Procal - This is odd or is it?
Old 06-02-2011, 12:07 PM
bmcgc's Avatar
Default Procal - This is odd or is it?
I enabled daytime running lamps (headlights only).
Whenever the turnsignal is activated the headlight on that side goes out, so the Jeep is one eyed.
As soon as the turnsignal is deactivated or self cancels the headlight comes back on.
Is that normal? Seems odd to me.
Old 06-02-2011, 12:59 PM
feeesh's Avatar
As silly as it sounds I suspect its a DOT requirement. I've noticed Audi's with the LED DRLs turn off when the turn signal is activated.
Although, I do believe some vag-com codes can fix the Audi's- sucks if there isn't a fix for the jeep.
Old 06-02-2011, 02:04 PM
Feasterdef's Avatar
I had day time running lights on a chevy I had back in 97 and it didn't do that. Hmmm
Old 06-02-2011, 02:50 PM
josh_jacklyn's Avatar
I'm running the procal on mine and I've never noticed this. Will have to check it out when improving home tonight.
Old 06-02-2011, 06:46 PM
checked on my way home, neither one of my head lamps turn off while either blinker is on. On your procal did you put it on th europeAn mode for your driving lamps?
Old 06-02-2011, 08:10 PM
fitzb's Avatar
From what i've seen, it normal. Mine does the same.
Old 06-02-2011, 08:15 PM
jeep_creep's Avatar
My 2010 doesn't but I know all 2010 dodge trucks and suv do it too, I think it stupid
Old 06-02-2011, 08:42 PM
Red Dog's Avatar
It is standard when using the Procal system. I was told it does that for safety. It is to draw the attention to the blinking turn signal. I get someone every once in a while tell me there is something wrong with my lights. I say thanks and laugh. I don’t think it is good or bad, hell I never see it. If you don’t like it, it is easy to turn off that option.
Old 06-02-2011, 09:00 PM
Little_JK's Avatar
I've noticed that in the day light with headlights on it's more difficult to notice the blinker. I'd think that the fender markers should definitely be blinkers from the factory also...
Old 06-03-2011, 07:39 PM
bmcgc's Avatar
I emailed Procal, they replied and said thats the way Chrysler does it. They recommended useing the fog lights as daytime running lights instead of the headlights.
Quick Reply: Procal - This is odd or is it?
