Procal with manual?
Procal with manual?
Hey people- I've just lift my Jk and put on 35's
Is it worth the 150$ to change my computer if I have a manual? Obviously I won't need to change the shift points set point. The only plus I can see is having a true MPH. Thoughts?
Thanks
Thanks
I would bite the bullet and do it. In addition to a correct speedo, it can correct your odometer (imperative for vehicle resale) and adjust the points at which your tpms sensors go off. It also has a host of other features that can be used down the road should the need arise.
Try to look for a used, unlocked one for a bit less.
The procal will change your speedo, odo, turn off the tmps light (if you didn't move the sensors), and allow you to get your steering wheel dead centered.
So is it worth it? That's up to you. But....for $50 more than the procal sometimes you can find a used superchips which adds code reading (wheel speed sensors) and tunes for the computer. So again- it's up to you and your driving habits.
Sent from my DROID4 using Tapatalk
I got the AEV one
Matthew
