Problems mounting EVO rear D-ring mounts and bumper fascia
I didn't have to hammer it to re shape anything I just needed to make the fascia sit farther down on the frame rails. Rubber hammer would be all that was needed in my case. Have you tried holding the d ring up to the fascia (outside of the frame rails) and making sure they will line up?
Well, after grinding and drilling out holes I finally have been able to get 3 of the 4 big bolts in. I did get the 4th and final one through, but now I can't get it to thread into the flag nut. The one on the passenger side went in easy, but I've spent 20 minutes or more on the drivers side.
What a royal pain. I didn't have this much trouble installing my old bumpers made by smittybilt - and trust me, those were a nightmare!
Headed to Home Depot to try and buy another bolt, hoping that will thread into the flag and I don't have to take the whole thing apart to pull the nut out and replace it.
I did test fit the bolts and nuts before I put them in and everything threaded fine.
Well, after grinding and drilling out holes I finally have been able to get 3 of the 4 big bolts in. I did get the 4th and final one through, but now I can't get it to thread into the flag nut. The one on the passenger side went in easy, but I've spent 20 minutes or more on the drivers side. What a royal pain. I didn't have this much trouble installing my old bumpers made by smittybilt - and trust me, those were a nightmare! Headed to Home Depot to try and buy another bolt, hoping that will thread into the flag and I don't have to take the whole thing apart to pull the nut out and replace it. I did test fit the bolts and nuts before I put them in and everything threaded fine.
I got them on. After 3 trips to Home Depot for parts and tools to grind....then some anger with a 10lb rubber hammer...then a breaker bar to get the cross threaded bolt to go through...I'm exhausted..
This will probably be the last EVO product I buy.
The response from Evo when I sent them the pics that I posted here was basically (not word for word, this is a shortened version), "I have never seen this before, you don't have to use the plates since you are using the fascia."
Really? I don't know, maybe I am overreacting, but seriously - this was more difficult to get on than anything smittybilt I have ever bought. I expected so much more.
Just to clear the air - I am fairly mechanical. I have installed lifts, shocks, F&R axle shafts, diff covers, skids, multiple bumpers and tire carriers, wired lighting, mounted my own beadlocks, etc. All bolt on applications like this should have been. I don't feel like this was an issue with me or a lack of equipment or skill. Just saying...
There were other issues with my order as well, but $hit happens, they took care of it. It just was not a good experience over all.
Good luck to anyone who goes this route. I hope you have a better experience than I did.
I installed mine a while a ago. It lined up and the only thing I had to do was use a BFH to persuade the passenger side to go into the frame. It is unfortunate of your experience.
