Problem with Expedition One bumper...
#21
Thanks,
js.
#22
I also installed a rear tire carrier from Expedition One a couple of months ago. The directions were sub par (need more pictures of the bearings installed properly) however James answered all of my questions and Sarah shipped out the missing parts promptly. I did not realize I too was missing the top and bottom race until reading this thread. but I'm sure they will take care of it.
still the best looking rear bumper/tire carrier system out there imho.
#23
Sorry to revive this thread, but in fairness to Expedition One, I needed to let folks know that they resolved the issue I had with the connecting coupling as soon as possible and shipped the part to me. This was not related to the bearings, but had to do with the coupler between the tailgate and tire carrier. They mfg'd a new part and sent it to me. I've been out of town, so I haven't had a chance to put it on yet, but I let EO know that I would notify folks on here that they do in fact care about fixing any and all issues, and will make things right.
#24
Hey fellas...I"m going to bat for Sarah and James !
I have there front and rear trail series bumpers/with tire carrier, and quality and service is second to none in my opinion! I received a tire carrier with the top bearing race missing and noticed it right away and did not install it on the spindle. But I"ve been working on cars and bikes since I was a youngster. The carrier and bearings assemble on the spindle just like a front wheel rotor on a front spindle on a car. It"s not rocket science. So I called James and Sarah about the issue, and was told they had a few call ins about the same problem.
The bearing races WERE installed in the carrier prior to goin to the powder-coating facility. As you know, the parts are heated to a high temperature in big oven, in the powder-coating process. Metal expands at different rates from the
distance of heat source....and unknown to everyone involved...the bearing races fell out to the bottom of the oven. So NOW the races are installed AFTER
the parts get back from the powder-coating facility. After a nice conversation with Sarah and James, I was sent a bearing race next day-air. Got the race the very next day...threw it in the ice box for a day, to contract it, next day, used a heat gun on the spindle housing where the top race gos and it damn
near falls right in place. Take a punch and small hammer and cross tap it and seat in. Now here is a little tip in adjusting the tire carrier and the tail-gate. You must match the tire carrier swing to the tail-gate swing so the coupling does not bind through the complete swing of the tail-gate. The tail-gate swings at an angle so the carrier must match the swing to the gate.
I was informed that there will be revised instructions for the rear bumper and tire carrier. For me personally it wasn't that big of a deal to install the front and rear bumpers and tire carrier. But like I said before, I'm sort of a backyard engineer and fabricator and I have been working on vehicles for a long time, but I understand some of you aren't so I don't mean to offend anyone's abilities to install such accessories. Just trying to help.
I am completely satisfied with Sarah and James' mechanical and engineering capabilities in building such fine products from Expedition One Off-Road Research and Equipment.
#25
Now here is a little tip in adjusting the tire carrier and the tail-gate. You must match the tire carrier swing to the tail-gate swing so the coupling does not bind through the complete swing of the tail-gate. The tail-gate swings at an angle so the carrier must match the swing to the gate..
#26
Although I think I've pretty much figured out the tailgate/tire swing thing, 'cause mine works ok, I am curious how you 'matched the carrier swing to the tail-gate swing'...what was your method of matching those together? I'm hoping the revised instructions have a little more to say on that, it was kind of vague...
#27
#28
Race falling out?
I'm glad things seem to be working out.
Has Expedition One found the root cause yet?
From what I see either the race wasn't installed or it fell out at some point.
I assume the two races come installed into the hub. There should be an interference fit to the hub. If not the outer races will fall out during handling before installation. They need to be pressed into the hub. If the races just slip into the hub the bore has been machined oversized and the bearing will never fit right.
An improper fit may allow the bearing to creep on the shaft or in the hub. Creep is defined as the inner ring slipping on the shaft or the outer ring slipping in the housing. This occurs when the interference fit is not sufficient for the operating conditions. As a result, creep can cause wear, ring fracture and excessive vibration. (rattle)
#29
right and snug down, it works like it was designed for. Remember the tail-gate
only swings about 95 degrees, its not a like a wheel bearing where it must with stand high RPM"s, even though the bearings are Timken Tapered Roller design, believe me the spindle and bearing/races are stout enough to handle the load. ( Designed for up to a 40 IN. tire and wheel )
