Problem after axle swap
#21
you know I was thinking about that drag link. It was in the bottom of the knuckle on the donor jeep. Just like factory. So is this drag link longer? Or angled different maybe? Or should it go on top of the knuckle instead of the bottom?!
#22
i just did some research and I have the basic st kit that doesent come with the high steer arm. It's this kit without the high steer arm. The jack base and pro cal box. So hopefully the drive line shop can straighten it out.
#24
The stabilizer will only mask the problem, you need to find out what is wrong and fix it or the death wobble will just come back later and likely be worse.
#25
it was the stabilizer and alignment. Just had it aligned at the local 4x4 shop. Bought a programmer there too. Fixed most of my shifting issues. I have a bad wheel sensor in the back right. Drives strait and smooth but the traction and abs lights are on due to the sensor. I'm learning these jks. The alignment guy also said if the axle isn't center and the steering wheel isn't center it will mess with the traction control too because there is a censor on the steering wheel that goes with the traction control.
#26
So I found out today you can't put auto lockers in 2012-2014 wranglers. When you turn a corner both wheels turn at the same speed and your computer thinks you're sliding. So traction control and limp mode kicks in and won't shift out of first until you turn it off and back on. I wish I would have know this.
#27
#28
I saw on some other forums that there is a wire you can cut under the console to disable the esp. I wonder if that will give me drivability until I find a better solution.
#30
Lemme get this straight. You traded your almost brand new stock axles from a 2014, for axles that you know nothing about, are 6 years older, probably have 100,000 miles, and have lockers so they have probably been beat on?
That sounds like a huge risk, I hope you didnt give him money.
The steering stabilizer did not fix your death wobble. The worn components you just installed and a needed alignment are likely the root of the issue.
This would be really really hilarious and unfortunate, but you sure the rear isnt lincoln locked?
