Problem with AEV Procal.
I just received my procal and went to programming my jeep. I couldn't get the day time running lights to work, so I attempted to do a reset but received 4 flashes then 2 which means vehicle ID issue. Well I then tried to program a different feature and now I continue to get same error codes. What can i do to fix this?
New Jeep? If it was previously owned it could be paired with another Procal.
If both are new then I would contact the place you purchased it from and get it straightened out.
It started out doing what it was supposed too when you program it, but when I couldn't get the day time running lights to work, I tried resetting it to start all over. It then started giving me error messages. I looked on here and found that the e brake had to be off and Jeep in gear for lights to come on. I went out and tried that and it works. I then tried a different program and it still gives the same error code. I can't change anything or reset now.
That does sound strange. Maybe disconnecting the battery for a minute will help, but that is a guess and a long shot. Sounds like the Procal itself needs to be " cleared" or reset somehow.
We've had problems like that and we did a reset then disconnected the battery to start over. This process seemed to work but it's a PITA...good value for the programmer but not the easiest to use because of all the dip switch settings you have to set. I'd try the reset then remove battery and start over...if that doesn't work call AEV for support.
