pro comp wheels !!
pro comp wheels !!
hi, anyone of you have these wheels I'm going to buy them but would like to see them on a jk
Pro Comp 6001 18X9.5 backspace 4.5 offset -19mm
I'm gonna run them on 35 s , any pics please or opinion !
Wide enough for what? The tire?
I'll back up for a second. What is the intended use of this new tire/wheel combination? If it's for off road purposes and on the trail both a lower diameter and narrower width is more desirable and less expensive. If it's for bling factor, I'm not the right guy to answer your question.
I actually have 2 problems, my 18 s have 5.5 back spacing and my tire are 325/60r18 (33x13.5r18 ) Id like the tire look better on a 10'' rim but 9.5 is the only one available, here spacer are 300 $ , if I trader My stock 18s + bit more money , I get another set of wheels ! without spacers !!
It's your call on what you want to do, but I'm not sure why you asked for opinions if you don't want to listen to them.
The wheel width doesn't have any effect on the tread width. Wider wheels make for less tire height and greater section width. Tires at the wheel width you are considering will be outside the fender flares, check your local laws regarding such. At the wheel width you are considering there is potential for rubbing on a stock front bumper. Beside that everything should be just ducky.
