pro comp stage 1 what do you think???
Old 10-24-2008 | 07:01 PM
1AK-JK's Avatar
Default pro comp stage 1 what do you think???
I want to lift my jeep soon, and i was looking at the pro comp 4" stage 1 kit. anyone have it? does it have any problems?
the fit could handel 37's but im gana put 33's i dont wana have to re-gear i dont have money for that right now. what do you people think?
i dont really do crazy rock crawling i love the dunes i go to the mud some times but i will head to the rocks but nothing hard.
Old 10-24-2008 | 11:03 PM
jeffl's Avatar
My local 4x4 shop says they install tons of the stage 1's and have had no complaints except slight rear drive shaft vibration. You may have to consider buying a different drive shaft. Any lift 4'' and above puts the stock shafts at a steeper angle which could lead to premature u-joint or cv-joint failure.
Old 10-24-2008 | 11:08 PM
jeffl's Avatar
I am considering that lift too but won't do it until I can afford at least the rear shaft . Right now I am runnng a 2.5 BB with 33's. Also thinking about the BDS 2 inch body lift and going with 35" tires. Click image for larger version
Old 10-25-2008 | 12:20 AM
1AK-JK's Avatar
wood i need to re gear for 35's?
Old 10-25-2008 | 12:23 AM
Piginajeep's Avatar
need? No..
but it sure makes it really nice driving!
Old 10-25-2008 | 12:27 AM
1AK-JK's Avatar
doesnt it put too much stress on my diffs? and cause them to blow? my frind had 35's on his jk and after about 12k miles blew both diffs. and i know thats a pain..... what about a 3 in lift will i have problems with the rear drive shaft as well?
Old 10-25-2008 | 08:47 AM
jeffl's Avatar
Folks that have automatic tranny's have been tearing off the cv boot on the front shaft after lifts because it changes the shaft angle. I guess it is not a prob with standards. Go to a good local 4x4 shop and talk to them. Not one that wants to sell you a 3000.00 long arm kit. If you explain to them how you offroad and what you want from a lift, they will select the proper equipment for you. Some lifts can void the factory warrenty too so do some research.
Old 10-25-2008 | 12:08 PM
1AK-JK's Avatar
what kind of drive shaft should i put?
Old 10-25-2008 | 05:06 PM
UGOTKERN's Avatar
Pro Comp Stage 1 4" kit only gives you 3" of lift. Not enough for 37's. I called Pro Comp and complained about the fact it only gave 3 " of lift. They are aware of the issue and sent me front springs that are true 4" and I bought coil spacers to bring up the rear to match.
Your gonna need differant hi clearance fenders and trim the pinch seams if you want to run 37's with the Pro Comp kit.
Old 10-26-2008 | 12:04 PM
1AK-JK's Avatar
really only 3 inches?? dAmn that sux.....
Quick Reply: pro comp stage 1 what do you think???
