Pro Comp 7033
Pro Comp 7033
I am about to pull the trigger on some wheels. I really like the pro comp 7033's in the 17x9. They have 4.75 backspacing. Does anyone have any info on if they will rub with 35's? I don't know if the .25 will cause any rubbing issues. Thanks for the help
My pro comp 1069 are 17x9 with 4.75BS, I run 285/70/17 and I can tell you there is still 1.25'' clearance between tire and sway bar at full turn. So with 12.5 wide tire I think you will be fine
