Pro Comp 6" or Evo Coil Over?
Which way would you go? Any reviews for the pro comp? Looks like the full Evo system is about 6 g's.
No direct experience with either one, but based on years of knowledge and reading of reviews on several forums, I would not put these two lifts in the same catagory on any level. If you can afford EVO, go with EVO. If not, do a lot more research before making a selection. There are several 6 inch lifts out there with great reputations.
Yes, ORE coilovers on all 4 corners are about 6k, but you may want to start with only the front
pair first, which is what I did. Getting the rears installed tomorrow. When I first got the JK,
I had the Skyjacker lift, which I did not like. Then went with the 3" full flex Teraflex, which I
really liked. Now coilovers. If I had it to do over, would have STARTED with coilovers from
day one!!
day one!!
