Pro Comp 2.5" CRT Coil Lift Install & Review
Old 10-15-2008, 06:11 PM
doc307's Avatar
I'm very interested in this also. Currently looking for a 2.5" lift.
Old 10-20-2008, 09:09 AM
Matt08jk's Avatar
Hey,
Ok, well I was able to install the lift on Saturday, all looks good, working on a report and lessons learned for you guys...hang tight.
Old 10-25-2008, 07:04 PM
Matt08jk's Avatar
I have been putting together the write-up,..in the write up section.
here: https://www.jk-forum.com/forums/jk-write-ups-39/pro-comp-2-5-crt-spring-lift-install-review-59318/
cheers
Old 10-26-2008, 06:44 AM
dyolfknip's Avatar
Originally Posted by Kevin S
I have the Pro Comp kit on my JK with the MX6 Shocks. Works great. Be prepared to replace the front driveshaft if you have an automatic. Read enough of the posts on line and when your driveshaft boot tears don't feel special. If it tears on the trail don't worry, you have plenty of time to replace it unless you wash all of the grease away. When my shaft boot tore on the trail, I was concerned about making it home, but I later learned from this forum what it was and why.
Dont think a little 2.5 is going to cause the same issues on the drive shaft as your 4"
Quick Reply: Pro Comp 2.5" CRT Coil Lift Install & Review
