Pro Comp 1 3/4" Body Lift
Old 11-20-2007 | 12:02 PM
BB-JK's Avatar
Default Pro Comp 1 3/4" Body Lift
Anyone install a Pro Comp 1 3/4" Body Lift? Please let me know your thoughts or issues and post pics if you have em.
Thanks
Old 11-20-2007 | 12:09 PM
Ctimrun's Avatar
Don't do it. Body lifts are !!!!!! There are much nicer ways of lifting a JK, and it is not much more expensive either!
Here is what came to mind when I saw your post. It looks absolutely terrible. I can't believe they would take this Jeep to SEMA. Alctually it would be something I would expect to be DUB related.
Old 11-20-2007 | 12:23 PM
BB-JK's Avatar
Well I have 265/75/16 on 16x8 with 4" backspacing
What would you recommend as a small lift? People are telling me my tires will rub fender with the rims I have
Old 11-20-2007 | 12:43 PM
Ctimrun's Avatar
I don't think it will rub with that combination but I could be wrong. The 4" of backspace brings your wheels/tires farther out from the vehicle so it may rub a bit if you flex your suspension.
You can get a nice budget boost lift from David at Northridge 4X4, let me find an example for you.....
The Full Traction 2" budget boost lift would serve you well and it only costs $125, add a little more if you buy their shocks too. Click below.
http://www.northridge4x4.com/proddet...?prod=FTS-7102
Old 11-20-2007 | 12:50 PM
BB-JK's Avatar
Isn't that the same thing as I was looking at before but from a different company?
http://www.4wd.com/productdetails.as...67&partID=9600
or would I end up looking like your posted pic either way?
Old 11-20-2007 | 01:06 PM
Ctimrun's Avatar
Yep that is the same thing. You posted "BODY LIFT" which is very different from a budget boost SUSPENSION lift. That Pro Comp suspension lift kit will work great!
Old 11-20-2007 | 01:10 PM
-MAW-'s Avatar
oh god
Old 11-20-2007 | 01:58 PM
BB-JK's Avatar
I think I confused the body and suspension lift. I thought suspension lifts involved more (shocks, springs...) and not just spacers.
Thanks
Old 11-20-2007 | 02:04 PM
Robar's Avatar
There are both kinds. A suspencion lift can in be a complete suspencior or spring spacers. A body lift does not adjust the suspension, only lifts the body higher off of the frame.
Quick Reply: Pro Comp 1 3/4" Body Lift
