Preventing sagging?
okay so lets say im sagging about an inch as of right now with all my parts on there and instead of a 3 inch lift its a 2 inch lift now from sagging.....could i add a 3-4 inch lift and it compensate for the lost sagging without have to extend all that shit???
2 door, 6 speed, soft top, 3.0 inch fabtech budget lift, rugged ridge xhd stubby with bull ring and smittybilt xrc 8 comp series with synthectic line and plan on adding the smittybilt xrc bumper with tire carrier...................thanks for helping me out man i appreciate this, ive been searching for days and want to maintain my lift while adding my mods but couldnt seem to find anything
This system utilizes the factory coil springs with 3" steel coil spacers. With the vast array of cab and motor combinations found in the JK, utilization of the factory coil springs with this system ensures that the vehicle will receive a full 3” of lift to clear 35” x 12.50 R17 tires. This system includes a replacement Pitman Arm, front and rear Trac Bar relocation brackets, Sway Bar mounts, front and rear Bump Stop mounts and more. Proper front-end alignment is insured with this system due to the included adjustable alignment cams. Also included is a front driveshaft boot clamp kit to allow additional clearance between the front driveshaft and transmission during full suspension articulation.
thats everything it has
thanks man i just talked to joe he said go with the 2.5 inch teraflex springs and it will give me 3.0 easily with my bumper and everything. thanks for the help!
I had a TF 2.5 budget boost, added bumper and winch, and sagged a LOT. I talked to Joe, who recommended to remove the front spacers, and if I have a 2 door, use 2.5" springs, and 4 door, use 3" springs. Since I have a 4 door, I got the 3" springs, and I sit perfectly level now. I still just have the spacers and stock springs in the back.
If I were you, I'd get the 2.5" springs and then add a 1" spacer later if it isn't enough.
I went with JKS ACOS, now I have adjustability to my lift. If I add a bumper I adjust. If I add a Winch, I adjust. Different tires with a slightly larger Diameter, I adjust. Get new springs, fine tune my adjustments for spring rate. look into it.
