PRESS RELEASE: TeraFlex JK Wrangler SpeedBumps Bumpstops
#21
3. If you have a non TeraFlex lift kit and you have bump stops mounted to the axle you can retain those and your shock/fender protection will remain unchanged with adding the SpeedBumps.
We do not have a rear SpeedBump application for lifts lower than a full rear 3” lift. We will have a special rear bump stop that replaces the upper factory unit with a closed micro cellular unit in the future.
For the rears, you replace the extension block, not the factory foam - right? So, in this case, I guess my question would be: What's the height of the rear SpeedBumps when fully compressed?
Thanks,
js.
#22
Sponsoring Manufacturer
TeraFlex Rep
TeraFlex Rep
#23
TeraFlex Rep
TeraFlex Rep
The SpeedBump uses the OEM bump stop in addition to the stroke (1.75") from the SpeedBump. The rear application completely compresses at 5,000lbs. The rear is designed for lifts with at least 3 full added inches in the rear. The picture shown is on a 4" lifted JK with a TeraFlex lift.
This shows the front SpeedBump with a 4" Lift
#26
TeraFlex Rep
TeraFlex Rep
#29
