PRESS RELEASE: Off Road Evolution EVO 44 Magnum Sealed Axle Sleeves
#81
Sponsoring Vendor
Some recommendations on catching the shavings are before drilling any holes, we have specialty tools at the shop, but a good way for the home installer to do this:
Tie a 3+ foot string/wire to a clean rag.
With a flashlight, inspect to see if any debris is in axle tube, if so remove.
With a long dowl (broom handle) push the clean rag to the end of your axle tubes all the way against your inner seals.
Put some grease on the end of your drill bits before drilling holes.
Drill the required holes holes.
Deburr drilled holes.
Pull on string to remove rag.
Some other tips before removing the rag are:
Carefully lower one end of your axle two inches or so.
On the lowered end, spray a genorous amount of brakeclean through the inner most hole on the lowered side and allow to drain out of axle end.
Lift lowered side of axle back to level
Lower other side of axle two inches or so.
Then pull on string/wire to remove rag.
Pulling out the carrier and/or replacing the seal is not necessary for proper install, but would not hurt if you wanted to do so.
EVO...
#85
Darn it! I ordered my Sleeves from another manufacturer 2 weeks ago! If I had known I would have gotten these. Sorry EVO, I would have loved to have these instead.
#87
Logan's also has great customer service, glad to answer any questions, etc.
#88
I like my Logan's! As I have looked into extra seals there are arguments for and against them. The Dana axles are designed with a dust boot on the outside but other contaminants can enter the axle up to the inner seal. Adding seals at the outer end lets in less contaminants but due to the nature of the mechanics will not seal completely and some contaminants would enter the tubes. The EVO sleeves would allow much fewer contaminants to enter than the Logan sleeves. However, they would also prevent any contaminants that do enter from escaping and being washed out. The Logan sleeves allow more contaminants in but by the same logic do not prevent the contaminants from leaving or being washed out. Whose sleeves are better, EVO or Logan? I think it's a toss up.
#90
Sponsoring Vendor
We also have our new "SBS" product line.
Remove your broken axle shaft and drive home safe
More details in the press release later....
