PRESS RELEASE: Off Road Evolution EVO 44 Magnum Sealed Axle Sleeves
Old 03-13-2009, 02:50 PM
  #71
john smack's Avatar
Ordered!!
Nice guys down there at EVO!
Old 03-14-2009, 07:47 AM
  #72
Sponsoring Vendor
Evolution's Avatar
Originally Posted by john smack
Ordered!!
Thanks for the good words
You will be happy with your 44magnum special.
Let us know if you have any Questions
Mel
Old 03-14-2009, 07:54 AM
  #73
john smack's Avatar
Just one question.....
how do I keep my girlfriend from spending my money so I can order more stuff frome EVO?
LOL
Old 03-14-2009, 09:05 PM
  #74
MOWrangler's Avatar
LOL
I can speak with experience when I say that a wedding ring does NOT fix that problem.
Old 03-16-2009, 08:21 AM
  #75
Sponsoring Vendor
Evolution's Avatar
Originally Posted by MOWrangler
Hey Mel... any chance you can post a preview of the install doc? (or Eddie - are you planning on doing a write-up here?)
Assuming the stars align correctly, I'm planning on getting with my buddy who welds the weekend after I get these in and would like to get the sleeves in and ready to weld before I get there. I'm getting trigger happy on my axle build-up.
We are working on completing the instructions, so they are not ready to post at this time.
The install is pretty straight forward:
Put 44 Magnum sleeves in freezer without seals Allow 3 hours previous to install
Carefully lift vehicle, support securely
Remove tires
Remove caliper, rotors and uni bearing
Remove axle shafts
Drill some holes
Slide in 44 Magnum sleeves without seals
Let 44 Magnum sleeves warm to room temperature
Weld drilled holes and around end of tube, both sides
Install 44 Magnum seals
Install axle shafts
Install rotor, calipers and uni bearing, torque to factory specs
Install wheels, torque to factory specs
EVO...
Old 03-16-2009, 01:17 PM
  #76
porters's Avatar
Similar, except that Mt Logan uses the factory seals. I assume the EVO sleeved replace the factory seals. But I could be wrong and these are just supplemental seals.
Old 03-16-2009, 01:22 PM
  #77
Remove tires
Remove axle shafts
Drill some holes
Install axle shafts
EVO...
How many labor hours are you running for your customers out there Mel? For reference to those of us who cant weld and will need a local shop to do this?
Thanks in advance.....
Old 03-16-2009, 01:51 PM
  #78
Sponsoring Vendor
Evolution's Avatar
Originally Posted by Mike_Engle
Is this the same type of set up that Mt. Logan offroad offers as well?
Sleeving axle tubes has been around for many years, most commonly used for trail fixes, correction and low tech axle narrowing and lengthening. Not something many people talked about. Since the JK and the couple dramatic pictures of the front axle tube fractures, the idea of sleeving the axle lends to being good insurance.
One of the issues with many versions of axle sleeves is that it prevents the use of secondary seals on the outer end of the axle.
Our EVO 44 Magnum sealed axle sleeves are designed to increase JK axle housing strength by 30% while incorporating dual seals to prevent debris from entering the axle tubes. Combining these two tried and true technologies will not only increase the strength of your axle housing, but will also help to prevent premature failure of the costly to replace inner axle seals.
EVO...
Old 03-16-2009, 01:55 PM
  #79
Sponsoring Vendor
Evolution's Avatar
The EVO 44 Magnum retains the factory seals and adds additional outer seals to prevent debris from entering the axle tube.
You still use factory seals.
Old 03-16-2009, 08:07 PM
  #80
MOWrangler's Avatar
The freezer... very COOL!
Remove tires
Remove axle shafts
Drill some holes
Any recommendations on catching the metal shavings from drilling?
Install axle shafts
EVO...
Also - Is there any need to take out the carrier? Would I be best to replace the inner seals while I am at it?
You guys rock!
Quick Reply: PRESS RELEASE: Off Road Evolution EVO 44 Magnum Sealed Axle Sleeves
