PRESS RELEASE: Off Road Evolution EVO 44 Magnum Sealed Axle Sleeves
Old 03-11-2009, 08:44 PM
  #51
RubiJK's Avatar
Originally Posted by evolution
I am not too concerned with the 44Mag install on your axle your numbers are not that bad and I still think most of that is in your axle Cs.
We also have some great tips that will help make the install as easy as possible.
All include in our directions that will be in every boxes of EVO 44 Magnums.
Mel
Thanks again Mel... Looks like I will get them on order then. Unfortunately, that means the Rock Star Skids that I also wanted will get leap-frogged... They'll be next for sure though. I look forward to meeting you at Moab too...
Old 03-11-2009, 11:17 PM
  #52
chuck45's Avatar
For general example:
2.50" Outer Diameter tube, .250" wall thickness (stock axle tube) has a bending strength of 1
2.75" Outer Diameter tube, .250" wall thickness has a bending strength of 2
2.50" Outer Diameter tube, .500" wall thickness (sleeved axle) has a bending strength of 1.3
Overall, a 30% increase is alot stronger than a stock axle without a sleeve.
3/8" - 1/2" holes work great
Andrew,
Thanks for the thoughtful answer, I agree that the 30% increase is good and well worth doing. Doesn't it strike you that this is just one more area where Jeep just saved a dime instead of doing it right. How much trouble would it be to have speced out the axle 1/4" or 1/2" bigger? The rear axle has a bigger OD and we hear of no problems bending them.
As to the holes - how many need to be drilled? It sounds like I'll be giving my Drill Doctor a workout
Old 03-11-2009, 11:22 PM
  #53
chuck45's Avatar
What is the stud, or cylindricl protrusion, at the top of the sleeve? Is it some type of grease fitting for the seals? Does this stick out of the axle tube like it looks like it would have too.
I've got Alloy USA CM shafts; I assume this sleeve setup is compatible with them?
Old 03-12-2009, 06:13 AM
  #54
Bunker's Avatar
I'm curious about aftermarket shaft seals also. I know the Superior shaft's require a different seal, how will this work with these? I plan on upgrading my axle shafts this year, need to make sure I have options.
Old 03-12-2009, 06:35 AM
  #55
stormrider's Avatar
I don't even have my jeep yet so I will probably hold off ordering these right now, but I'm just wondering what the price will be after the "special offer" goes away? Will it still be the same for the kit but without the option of the $10 cheaper Gussets?
Old 03-12-2009, 06:57 AM
  #56
northsidejeepin's Avatar
I would assume this is where you drill the holes in the actual axles tube, and these fit in place to be welded, kind of like locator pins.
Old 03-12-2009, 07:51 AM
  #57
Sponsoring Vendor
Evolution's Avatar
Andrew,
I would not be so tuff on Jeep
It handles the stock tires fine
As far as how many holes
All the directions and tips will be in the Boxs
Mel
Old 03-12-2009, 07:57 AM
  #58
paramaniac's Avatar
why does my cursed ex wife have to take so much of my hard earned money.....
or at least it seems that way when i see something i would like to have for my rig.
EVO, any chance you have install instructions online to take a look at?
Old 03-12-2009, 09:02 AM
  #59
porters's Avatar
For fun here are pics of my sleeved axle for reference.
Old 03-12-2009, 09:44 AM
  #60
I just Ordered mine
I cant wait to get these puppies installed Also grabbed the c2 gussets and the powder coated black Evo Fairlead.
Quick Reply: PRESS RELEASE: Off Road Evolution EVO 44 Magnum Sealed Axle Sleeves
