PRESS RELEASE: Off Road Evolution EVO 44 Magnum Sealed Axle Sleeves
Old 03-11-2009, 02:46 PM
  #31
Sponsoring Vendor
Evolution's Avatar
Thanks for all the phone orders.
Our website has now been updated to preorder over the internet.
http://www.offroadevolution.com/stor...prod=EVO-44MAG
EVO...
Old 03-11-2009, 02:57 PM
  #32
bigbluejk's Avatar
Originally Posted by MattC
Cash it tight right now....Whats the non pre-order price going to be?
I am in the same boat. I would love to have a set, but it is going to be a month or so. I would love to find out the price they will be listed at after the pre-order. Looks like more quality EVO stuff!
Old 03-11-2009, 03:08 PM
  #33
Amway Man's Avatar
These go inside of the axle housing? Can a run of the mill 4X4 shop do the work and not be confused on it? I dont have a welder and would love to get these done at a low intro price
Old 03-11-2009, 03:14 PM
  #34
Suffolk JK's Avatar
Originally Posted by evolution
No super mad skills required, not even super welding skills.
Drill and plug weld.
So you don't need to weld the actual outer edge of the tube to the outer edge of the factory tube (where the shaft comes out)? The plug welds will hold the sleeve for good?
Old 03-11-2009, 03:27 PM
  #35
RubiJK's Avatar
I really need to sleeve my front... I mean I really needED to sleeve my front axle. What is your opinion of both of my front axle tubes are already slightly bent. It is very slight, and has been the same now for about 9 months. I can only imagine if they are really bent there will be no way to press these in, so I can imagine you will answer will be that it depends on the severity of the bends... My camber is 1.2* driver, and 1.1* psgr. I honestly have no idea what the stock/not bent camber is to tell how much these have bent. Anyway, whatcha think?
Old 03-11-2009, 03:43 PM
  #36
JCKnauer22's Avatar
Just placed my order. Only went with the sleeves and gussets. i figured the rest can wait for now. i'm so happy 2 have just purchased a new mod!
Old 03-11-2009, 03:56 PM
  #37
Amway Man's Avatar
Ordered!
Got the C2 axle gussets too, figure I might as well start it off right, hope to install by the end of april!
Old 03-11-2009, 04:08 PM
  #38
Sponsoring Vendor
Evolution's Avatar
Thanks for the comlements
The pre order special is about a $25.00 value
Mel
Old 03-11-2009, 04:14 PM
  #39
Sponsoring Vendor
Evolution's Avatar
Yes if the shop you go to, can replace a axle shaft and also has a welder. Thay will be able to do the install.
Mel
Old 03-11-2009, 04:31 PM
  #40
Suffolk JK's Avatar
Are the plug welds the only thing needed or does the rim of the tube have to be welded allthe way around the outside edge of the axle housing as well?
Quick Reply: PRESS RELEASE: Off Road Evolution EVO 44 Magnum Sealed Axle Sleeves
