PRESS RELEASE: Off Road Evolution EVO 44 Magnum Sealed Axle Sleeves
Old 06-17-2009, 04:07 PM
  #121
dburgette's Avatar
Originally Posted by evolution
You have it right. Its called a needle grease nozzle.
EVO...
Okay...that's pretty straight forward. Thanks EVO
Old 08-22-2009, 10:55 PM
  #122
simov_mincho's Avatar
Thumbs up
Installed my Magnun, the effect is very good.
Axels were rusty,now protected, very strong.
Installation was very easy
Can you tell me, do I have to pour more oil in the differential.
You're very good "EVO"
Old 08-24-2009, 08:10 AM
  #123
Sponsoring Vendor
Evolution's Avatar
Glad you like them.
You do not need to add more oil than what is recommended for your axle.
EVO...
Old 09-01-2009, 09:12 AM
  #124
Ryanc's Avatar
Is there any problems installing these after the gussets. If there is a slight deformation, will these still slide in?
Old 09-01-2009, 09:25 AM
  #125
Sponsoring Vendor
Evolution's Avatar
There should be no problem. They will slide right in before or after. This was a consideration that we took into account when designing the EVO 44 Magnum Sealed Axle Sleeves.
EVO...
Old 09-01-2009, 11:19 AM
  #126
phouck's Avatar
I just ordered mine from northridge along with some axle C gussets and CA skids. Probably be a little while before I can tackle the install though.
Old 09-01-2009, 12:12 PM
  #127
Ryanc's Avatar
EVO...
Sweet, just ordered a set.
Old 11-17-2009, 10:32 AM
  #128
joneszj's Avatar
Will these sleeves interfere with this Super 30 kit? http://www.northridge4x4.com/proddet...A-S30-EV30-ARB
Or will it all go together A-okay? I'm looking to seriously strengthen my front axle without switching over to a d44...
Old 11-17-2009, 10:36 AM
  #129
Sponsoring Vendor
Evolution's Avatar
The Super 30 Kit will work with the EVO 44 Mags.
EVO...
Old 01-13-2010, 04:43 AM
  #130
FJ80fornow's Avatar
Default Evo 44 Magnum with RCY axles
I am finishing up my install, and as the title suggests, installing RCV CV style axle shafts at the same time. The grease cup on the RCV axle is pushing up snug to the EVO 44 axle sleeve, so it it will be rubbing as it rotates. Has anyone else installed this combination? Any of the same issues? Could the red rubberized RCV dust cup be trimmed a bit without sacrificing it's purpose?
On another note for those that have installed only the EVO 44 magnums, what is the distance between the sleeve and the inner most flange on the U-Joint of the stock axles?
Quick Reply: PRESS RELEASE: Off Road Evolution EVO 44 Magnum Sealed Axle Sleeves
