PRESS RELEASE: Full-Traction Suspension 3″ Economy Plus Lift Kit
Former Member
Originally Posted by Robar
You get what is in the description and pic. "Complete kit" depends on your needs and definition. This is the Economy kit. This will get you a 3" lift. If you need control arms or other components in the future they can be added at that time.
We do sell control arms seperate for those wanting upper or lowers to adjust pinion and caster
Former Member
Originally Posted by BigJeschke
Gonna have to add this to my list of possibilities. I'm thinking this and some fox or elka shocks.
Former Member
All of our JK track bars come with rubber on the frame end, this kit comes with rubber on both ends. You can upgrade the rubber end at the axle end to a heim joint if and when you decide you want to.
Former Member
Former Member
You won't rip it from the lift alone, with the correct length shock you can run the stocker for awhile, but know the stock shafts are weak and will need replaced.
The economy kit is pictured in the first post. The Ultimate 3" lift can be seen here:
http://www.full-traction.com/detail....TID=414&NOTES=
