PRESS RELEASE: Full-Traction Heavy Duty Replacement Cross Member
#41
#42
Former Member
#45
Full-Traction Suspension introduces a new Heavy Duty replacement Transmission Mount Cross Member for the 2007-2010 Jeep JK Wrangler/Rubicon. This new bolt-in unit is designed for serious rock crawling abuse. HD crossmember utilizes factory mounting locations. No drilling required. Quality laser cut 3/16″ steel construction with added skid plate to protect the exposed cross over exhaust system. This is the solution for the jeeper with a damaged factory cross member. Works with any short arm kit and most long arm kits on the market.
This unit is 100% made in the U.S.A.
Part # FTS7370 fits 2/4 Door
Price - $389.95
For more information regarding the all new Full-Traction Suspension 3.0″ Premium Plus SRS™ kit, please email them at: chrisb@full-traction.com or call at: 800-255-6464
#46
Former Member
Both lines are available factory direct
#47
Does the new cross member improve ground clearance, also I checked your website and didn't see the transfer case skid plate or auto tranny skid plate to work with this?
Thanks,
Jon
Thanks,
Jon
This will work with any JK 2007-2011. If your running the auto tranny skid it will need changed to our Purejeep engine skid. The stock transfercase skid does not work with the replacement cross member
PureJeep engine/t-case skid.
#48
Former Member
#49
Well this is the best thing I've stumbled on in a while. I'm on my 3rd stock one so far. Only down side is they have all been free. Thanks for a solution to this problem.
