PRESS RELEASE: Full-Traction Heavy Duty Replacement Cross Member
JK-Forum Founder
Full-Traction Suspension introduces a new Heavy Duty replacement Transmission Mount Cross Member for the 2007-2010 Jeep JK Wrangler/Rubicon. This new bolt-in unit is designed for serious rock crawling abuse. HD crossmember utilizes factory mounting locations. No drilling required. Quality laser cut 3/16″ steel construction with added skid plate to protect the exposed cross over exhaust system. This is the solution for the jeeper with a damaged factory cross member. Works with any short arm kit and most long arm kits on the market.
This unit is 100% made in the U.S.A.
Part # FTS7370 fits 2/4 Door
Price - $389.95
For more information regarding the all new Full-Traction Suspension 3.0″ Premium Plus SRS™ kit, please email them at: chrisb@full-traction.com or call at: 800-255-6464
JK-Forum Founder
Honestly, why nobody had come out with this sooner is a mystery to me as everyone I know has got a trasmission cross member beat to all hell. Two thumbs up go out to Full-Traction for making this super beefy HD cross member
Former Member
Former Member
It's the same cross member as the long arm kit without the arm bracket. We're working on the upgrade for this to our long arm system. It may just be welding the brackets to the cross member.
Is this crossmember similar to that offered by Rubicon Express?
Does anyone know if this skid will work with the Rubicon Express crossmember? I would assume that small mounting modifications would need to be made, but do the bends in the skid allow this to fit with the Rubicon Express crossmember?
Thanks
Thanks
Former Member
Thanks
Thanks
From the RE lift I looked at in the Mopar booth at EJS. It appeared to be the same as the factory cross member with lower control arm brackets.. So no this will not work with RE long arms cross members. This also ties into the bottom of the frame. I believe this would be the hang up.
