Preliminary 2012 Pentastar Gear Chart (beta)
#42
It's not right according to the table. According to the table he should be at about 1900 RPM, unless he actually has 3.71 gears (which is what I think he was getting at) or his tires are actually measure closer to 29" instead of 33".
The table seems to be accurate to me. I have "35's" on a 2012 JKU auto with 3.73 and I'm turning around 2100-2200 at 70 MPH; however, my Goodyear Duratracs (315/70R17) actually measure a tad under 34", so the RPM's listed on the table seem accurate in my case.
#43
#44
#45
Originally Posted by flatattack
Well, I can't speak for him but I'm turning 305/65 17's which actually measure about 32.25". At 70 mph I spin right at 2100 rpms.
#46
Originally Posted by Happybg81
So the chart is wrong then. Otherwise turning 2100 at 70 with 3.21 you would be running about 29" tires.
#47
I'm not claiming the chart incorrect, just giving my real world experience. I will be regearing to 4.56's regardless of rpm. And will eventually bump up to 35's, but for the time being I'll stick with the 305/65 17's, 3.21's auto JKU.
#48
Yep... definitely sounds like the 3.21 gearing column might be off then. This is probably the type of feedback the OP was looking for. Could be a simple formula mistake assuming he used an Excel spreadsheet to create the table.
