PR44 help needed
PR44 help needed
Ok so im going to be ordering a prorock44 as soon as i get my insurance check. (see my other thread) Im wonder what i will need. Im hoping that the majority of my stock stuff is still good inside my stock 44. Do i have to buy a driveshaft with different yokes or can i stay with the stock shaft? Should i get the unlimited one? I have the teraflex 2.5" for the 4 door and mine is a 2 door. i got about 3.25" out of the kit plus im putting on a front 1/2" spacer. thanks for your guy's help!
Go for the unlimited. Thicker tubes, and the caster correction is great.
From looking at your pics, is the front driveshaft blown? Or is that oil leaking onto it from above? You can stay with the stock shaft, but plan on going to a double cardan with new yokes at some point, so it may as well be done now.
You should also have your shop rip that axle open and check it out. If more than just the housing is bad, look at the standard PR44 so you can use any locker, and aren't stuck with the rubi locker/35sp arb upgrade.
Sponsoring Manufacturer
Well this is all insurance. my jeep was crashed. i dont have the funds to change out gears and lockers and everything for the rear. so im going to stay with the stock stuff for now. Do you guys have housings in stock that i can pick up when i get the check?
Stock is a maybe. We make these housing by batch. PM sent.
