Power steering leak on inclines?
Searched to see if this was common or if anyone else has experienced this issue, but found nothing, so I thought I'd ask.
The last 2 times I've been wheeling I come home to what appears to be power steering fluid leaking under the hood. The fluid seems to be coming from the reservoir because it gets all over the air box.
Is this common? It never leaks unless I've been wheeling, so I'm thinking it's coming out when I go up or down steep inclines.
It may be over heating and pushing out of the reservoir? Or you've got a restriction in the return line from the reservoir to the power steering pump?
Overheating seems plausible, although the last outing we didn't do anything real extreme. Is there any way to remedy the overheating problem? Do they make a power steering fluid cooler?
I took it in to brakes plus and the guy said they make a special cap to stop the spillage, but I haven't been able to find such a thing online so I feel like he sent me snipe hunting 😠
It could be overheating...mine gets hot but it doesn't leak, it's more like its sweating Is your cap damaged?
You can install a simple cooler & larger reservoir to increase capacity If you really want
1. Try with it cold, steer the wheels back and forth. With the reservoir lid off, watch to see if the fluid is being pulled from the reservoir fast enough.
2. Try with it hot and see if that makes a difference.
I'm sure there's other stuff to try... there's a fellas on her that have way more experience than me.
I have the same issue. I cannot find were its at either. But mine is on my air box too. I have to keep refilling the fluid also. So the story is I did a donut back in February and broke the pulley in the power steering so I purchase a new one and that's where I'm at now.
