Pot Hole Wobble?
Pot Hole Wobble?
Hello Everyone. I recently moved to NJ and it seems like there are more pot holes than road around here. This would be nice if I was in the woods, but I would like to drive peacefully to the store when I go out. I do not know if I am experiencing death wobble, but every time I hit one of these pot holes my steering wheel starts to shake uncontrollably. When I slow down it goes away. I have a 4" TeraFlex lift with 35"KM2's, and a teraflex steering stabilizer. Can anyone tell me what causes this and how to fix it? Thanks!!
You're wrong. Leaking stabilizer is not the cause of DW. You just masked the problem. You will have DW later if you don't check your front trac bar, directions parts and control arms
If you have to slow down to make it stop its death wobble. Plenty of info, do a search. Are you stock or lifted?
Oh and I feel you on the potholes.
Here in NY I feel like I got beat up by a 300 pound man by the time I get to work.
Good to know my taxes are going into someone's pocket because the state is broke and I have yet to see any road crew filling potholes.
I believe my Jeep has the same problem. My most recent issue of JP magazine went over common failures on the JK. Ball joints was on the list if you increased the tire size. It would be a good place to start.
Bump steer is actually merely masked by a steering stabilizer.
Its typically caused by the linkages not being parallel, so that when the tire is deflected by a bump, the difference in the angle creates a steering effect, called, oddly enough, bump steer.
