possible driveline issue.
what he said - your rzeppa joint is starting to fail. you really need to get a new drive shaft now as you are totally out of time. a good 1310 u-joint style shaft is what i would recommend and, being that this is a rear shaft, you will need to get adjustable rear upper control arms to set your pinion angle as mkjeep said.
thanks for the help.
any suggestions on what shaft to get?
in spite of what some people will try to tell you, drive shafts are pretty much drive shafts. the only real difference is in the components used. regardless of who you go with, i would recommend getting a 1310 shaft with replacement yokes (not flanges or adapters) and spicer u-joints. i like coast shafts but only because they are sold with both and all for about $450 at northridge4x4 with FREE shipping. other manufacturers who have shafts for the same price use cheap chinese u-joints.
I had this exact thing just happen. The pinion angle of your drive shaft is causing the grease to be thrown and causing the noise. I had to replace the drive shaft, got a Tom Woods 1310 for $454, and then had to get some adjustable rear upper control arms to reset my pinion angle. Those were another $200.
i wish i had 650 to drop on it right now but i dont. do you think a new driveshaft will hold up for an extra two weeks until i could get upper arms?
you will have big time vibrations that could lead to a broken transfer case. might want to see if you can find a used factory shaft to hold you over as a temp fix
