Portable Air Compressor outside of vehicle mounting
Ever thought about raised floor in the rear? A lot of the stuff you mentioned keeping under your seat is stuff I keep in my trunk....one of the best mods I did. I realize we all have different builds, just throwing it out there.
Under-Floor Storage - JKowners.com : Jeep Wrangler JK Forum
I'll likely just go with my original mounting area idea and see how it works out. If it works out, I'll post a write-up. If it doesn't, I'll post to let everyone know what went wrong so no one considers follows my stupidity.
Great box.....funny how we all see diff things cuz I still see a trunk in there! LOL. I'm subscribed and will look forward to hearing the experience. $50 for a HF compressor is limited downside. My main concerns would be mud and water, but you might not encounter those things to teh same extent. Love to see what you come up with.
I'm hoping with the silicone seal that most of the mud will be kept out. I still have the air filter openings to worry about, but those seem pretty well tucked away and face toward the pump. Gburkett responded and seems to have had good luck mounting under other vehicles. The thing I was most concerned with is that moisture gets into the motor and then the motor rusts and freezes so that it becomes seized up.
That looks like a pretty good solution. More than what I would want to spend for a simple bracket. It would annoy me to have to lift up my hood and run hoses across my engine bay to fill tires. That's the reason I want to try some other location. Running wires won't be too difficult for where I plan to mount. They'll be mounted to a frame rail and then you just put some wire loom around your positive wire and run it through the frame rails until you reach the engine bay, then straight up to the battery.
I mounted my compressor back by my rear sub, just made a little bracket coming up from the bolt there to the back seat bolt. Did not make the mount any wider then the sub enclosure so it be protected from things in cargo area while wheeling.
I mounted my Viair OBA in a cradle where the evap used to be. I have to run the compressor once or twice a month, otherwise it seizes up. Used to have one under the hood and it seized up after not using it for a year, assuming it'll seize if mounted anywhere outside the passenger compartment.
On the plus side, it's out of the way and I have a connector on the bumper that's easy to access.
i ordered this
it is sealed can and could be mounted inside or out under or just portable. Ill prob just rig up a pre attached wire pair from battery
to spare me the hassle of clipping to the terminals on the battery each time. It should work pretty well for my needs/ another thought that might be doable to mount under your jeep if you wanted it sealed some how and you could prob do plenty of modifications to suit your needs from the area where you store tools . you could drill holes in it and use water tight heyco fittings to relocate switches/ air hose whatever and secure it in a location you can access easy maybe
But seeing you already bought compressors you could maybe mount them in a ammo can as well and branch off out of the can with these water tight fittings to both sides of your jeep like a junction splice box / if that would work for you ?
https://www.youtube.com/watch?v=eBgxfNYoXVk
https://www.youtube.com/watch?v=S6b3we3Pxb8
