Poison Spyder Rockerbralwer + Carrier
Ok so im putting some beadlocks on my jk that are meant for a tj. I have adaptors for the 4 but instead of getting a 5th i decided to put just change the studs. Well now that i got them out i cant get them hammered back through. Does anyone have any tips? The reason i dont know the best way is because i wasnt the one that put them in the first time.
Sent from my iPad using JK-Forum
I install studs with a lug nut and a few washers. Put the stud through the hole and then put the washers over the stuff then put the lug nut on and tighten the shit out of it with an impact. Done. Now if you don't have air I have done the same thing using a breaker bar instead of an impact.
