Poison Spyder Rock Brawler - Tire carrier sagging
Hello, I have a Poison Spyder Rocker Brawler and the tire carrier is sagging, meaning I have to lift the tire carrier to clear the bumper. I have loosened everything and put my high-lift jack on the carrier raising it and then tightened everything back up. I still end up with the sagging. Is feels like there is play in the hinge barrel. It feels like the tire carrier has about a 1/4" of play up and down. Any ideas on how to fix or adjust this??
Use a set of channel locks if you have any or a super large wrench. I used channels ka and mangled mine a little. You could maybe wrap the cover best you can before applying the channel locks. You have a rubber glove maybe put that on and try to loosen the cover by hand.
I bought a 24" Olympia crescent wrench off Amazon for less than $30 to my door. I saw that poison spyder is now shipping a laser cut wrench with new bumpers so you might want to give them a ring and they would send one out. Good luck!!
Below is my son holding the little baby crescent wrench!!
I soaked the thing in PB rust blast and used I used a big pipe wrench and a set of channel locs and the freaking thing won't budge. Trust me, I man handled it...
I'm at a loss at the moment... any ideas??
Let the PB Blaster soak for a while maybe it will free it up. When you get it off maybe apply some anti seize. You have me nervous now I may see if I should maybe check out my cover to see if I am gonna have the same issue. I hope not, I put a much thicker O-ring to assist with keeping moisture out.
I am out of the country at the moment but should be back in a couple days, but I would be glad to help you out when I get back if you don't have it squared away by then.
