Poison spyder diff covers clearance
I'm running a 3.25" Rusty's lift on my 2011 Jku. I'm getting ready to order some differential cover and I'm wondering if my front and rear trac bars will clear. Anyone have experience with these covers and aftermarket trac bars?
I'm running pro comp 4" (probably Only 3") and track bar clear at full stuff on front with poison spyder diff covers. When I ordered the covers I asked about the clearances, and northridge said if you have a decent amount of lift (2.5" or more) then you will be fine. My tie rod just grazes at full lock, but I think it's bent back a tad from the rocks.
The rear will clear no problem if you have a relocation bracket.
I'm running pro comp 4" (probably Only 3") and track bar clear at full stuff on front with poison spyder diff covers. When I ordered the covers I asked about the clearances, and northridge said if you have a decent amount of lift (2.5" or more) then you will be fine. My tie rod just grazes at full lock, but I think it's bent back a tad from the rocks. The rear will clear no problem if you have a relocation bracket.
