Poison Spider Body Armor Install Question?
Monday I am going to order a bunch of Posion Spider stuff. Brawler Lite Bumper, Crusher Fenders, Rocker Knockers, and the Body Armor.
The body armor has an optional rubber body armor liner. Is anyone using this or just mounting them directly against the skin? Is the nut-sert installation tool provide easy enough to use or are there any tricks or tips? I install riv-nuts at work often but we use an air tool. These look to be the same thing but the thickness of the metal is the difference.
I searched the threads and only found four talking about installation. Not to much mention of the nut-serts. Must not be to much of an issue.
The shop that did my install didn't use the underliner but I think it would have been a good idea. I did notice that there is rust at all of the holes even though it was just put on in September. I talked with Rick @ PSC and he suggested I talk to install shop. Seeing the guy on Tues and will send you msg about it.
The rubber liner is a good idea to protect the body. The prep work on installation is key, powder coating and painting the drill holes to prevent rust. The nutserts are a flaming pain in the ass without a real tool to do it. A real tool is $200+ and it comes with long handles. Any of the inexpensive ones are small in size and require a lot of elbow.
The psc quality is top notch, which offsets the pita factor. Good luck and have fun
Originally Posted by dcharge74
I believe that you're supposed to use touch-up on the holes before installing the nutserts. Sounds like your shop didn't do it. I'm picking a set of these up in a week or so, and I think I might even go the length of putting a dab of silicone on the nutserts before putting them in.
