Pointers.
You planning on putting in new front springs? The stock ones will sag a couple of inches with the extra combined weight of the steel bumper & heavy winch.
JK-Forum Founder
if you don't have it already, pick up a metric tool set that comes with an 18mm socket. i would also get a 6" ratchet extension as it can be tough to get the nuts out without one. the plastic air dam and trim piece on top have screws holding everything in place that may or may not work. if not, a long screw driver or small pry bar will help to just pop them off.
Originally Posted by Croce
I believe you want to mount the winch to the bumper first before installing bumper.. I could be wrong but i believe thats what ive heard
Should I just get the teraflex leveling kit till I have the money for the 2.5 coil lift or would the leveling kit even help with the rake from the bumper and winch
