Please help with control arms
I have had the AEV dual sport xt 2.5 lift with the geomtry correction brackets on for about 6 months. This is my dd driver and I really love how this kit handles on the road. The thing is I have been doing a lot more off roading at Rausch Creek and a few other places and my lower control arms are taking a beating. I have been thinking about removing the brackets and installing either Rock Krawler or Teraflex arms for more clearance. My real concern is if I do this am I going to lose my on road handling? And if I do who makes the heaviest with the most clearance arms? If I do I am going to replace all 8 of them. Thanks for the help Charlie
RK will give you the best clearance. You may notice a difference on road handling. I'm using WP control arms with standard rubber bushings. I would like something with a flex/johnny joint for the articulation, but I hear the basic rubber bushing style is silent and more absorbing/comfortable for street. I'm still on the fence as well, for now my WP bushing control arms do the job all around.
I run all 8 RK arms. They are super heavy duty and offer a higher clearance than most. I can't compare the ride to your AEV as I have never rode in an AEV lifted vehicle but mine drives very good on the road, fantastic flex off road. RK 3.5 suspension, drag link flip, fox 2.0's, 37" MTR's.
At 2.5" of lift, your drive even without the brackets shouldn't be terrible. Adding a set of front lower adjustable arms like you are thinking about will basically do the same thing as the AEV brackets do. That is simply getting your caster back in line. There may be some benefit to the brackets since they return the angle of your control arms back to stock but I don't think that will translate to a way better ride than using adj arms at your height.
Go grab the RK arms, set them to 23 1/8" and your Jeep should be back or very close to stock caster (an alignment after installing can't hurt!). That will give you a ride that is very close to what you have now with the brackets. But you will gain a lot of clearance for off-road use.
Sponsoring Vendor
Rubber bushing do help obsorb road viberations and noise. Honestly I did not notice much difference or any difference with the Johnny Joints we run on our control arms.
cant go wrong with these....proven joints on both ends and on jeep adjustability makes it easy to dial in.
EVO: Suspension / Steering, EVO MFG(8) Adventure Series Front Lower JK Control Arms
