Please help! Air compressor
I purchased the ARB high output onboard air kit. CKMA12/24 kit. i have everything wired up as it says besides the red-yel to Ignition and the blu-wht to dash illumination. Im lost… i can't figure out where these go and nothing is working. Please anyone help me out a bit thanks!
The red/yel ignition wire can tap to the cig lighter. This wire triggers power to the compressor only when the jeep is running. The blue/white is the illumination wire that illuminates the little light on the ARB switch when the headlights are switched on. I don't recall which circuit to tap. Search the interwebs for the correct wire.
Should be the Blue with violet. I found a thread -
Project-JK.com - Jeep JK Wrangler Resource » ARB High Output On-Board Air Compressor Under the Hood JK Installation Write-Up
