Please help!!
Please help!!
so wile putting all of the stuff back on the jeep i tried to get the center console back on after raptor ining it. i had to get it was in 4x4 N to get it off, to put it back on it needed to be back in 2WD. so i attempted to do so in the normal routine (put in N, shift in 2WD, shift back in D). when i shifted towards 2WD it got stuck in the 4X4 position and made a huge POP. now the jeep will not go into D, R, N... nothin. getting AAA to come get it but im just wondering if anyone knows what the hell happened
There is a crappy plastic bushing that holds the transfer case lever onto the linkage. It may have disintegrated. You can zip tie it for a quick fix. There are several threads on this issue. Google JK transfer case linkage problem. This same part is down in the transfer case side also. Db cheap plastic parts aren't designed to hold up.
