please help
dialing in what works for aligning a lifted jeep requires someone who is familiar with how far out of factory spec he needs to go (coils W/ trac-bar experience)
Sounds like you have some bump steer. oddly enough I didn't have bump steer till I put the stock tires back on for winter! go figure
I would bet it is your track bar. If the bolts are tight, take them out and inspect the bolt holes on the frame and axle brackets for the track bar. The bolt holes may be wallowed out. If they are, that is the issue and there are a couple of ways to fix them. Either by welding grade 8 washers over each hole or by putting a Full Traction reinforcement bracket and brace on the drivers side and a JKS steering stabilizer relocation bracket on the axle side. Those two brackets will cure the wallowed out holes. I have the washers on mine now, but just ordered both of those brackets. Hope this helps.
Thanks guys i will check it out. at first i thought it was just because i am still running stock wheels and tires but i dont know alot about it. Only does it when i hit something pretty hard and when i hit more on the drivers side when i hit like a bump square with both tires it doesnt so it but its driving me crazy and it shakes hard im worried something is going to fall off lol
JK Forum Regional Rep
I recently put a lift kit on.my 07 wrang X and i took it to a 4x4 shop n got an alignment done and had my axels centered but not long after when i would hit a good bump i get a pretty good vibration in thw front it last a few seconds then stops i was told that it could he my ateering stabelizer is this true or is.it something else
Is everything tight?? Or did you torque the track bars to spec? When I put my lift I had 'Em tight, but kept getting a shimmy and flighty steering. Crawled under and did track bars to 125ft lb and everything was perfect.
This vid was put together by TeraFlex, and shows what to look for in the geometry
http://rides.webshots.com/video/3016...02496289IjoMUo
Do you feel it in your steering wheel also? I just installed my rc 3.75" lift and have similar symptoms.
Going to try the following mod to see if it helps.
Pg 2 has pics if your not mechanically inclined.
https://www.jk-forum.com/forums/show...steering+clunk
